    Dismiss Notice
Shower bath mixer taps water flow / pressure
Discussion in 'Plumbing and Central Heating' started by Kaylouise, 25 Aug 2013.
  1. Kaylouise
    Kaylouise
    25 Aug 2013
    2
    Thanks Received:
    Sussex
    Country:
    Good morning, i'm new here ! Mechanic by trade but enjoy diy. Now......our bath ( 1st floor house , tank in loft) did have 2 separate taps . We had a rubber push on shower hose and head. Due to wear and tear we decided to change this to a mixer tap /shower. I bought one which is a complete unit but with one lever tap in the middle and the hose comes out from under the one main water exit. Husband fitted it .......water flow way too slow....more of a trickle. After this I did some research on the tap i'd bought which said recommended pressure 0.5 bar :oops: . I then discovered how to work out what pressure we have and how far away the tank is vertically....0.2 bar....so , I have now found a mixer tap that says it will work on 0.1 bar....i'm assuming this will be the correct one to buy . The water in the cistern/ sink taps is exactly as it was before - no air or crap in the pipes. Good flow and pressure. In your opinions should this work ? thank you in advance for your help
    And yes , I did admit to my husband I bought the wrong one !
  2. Sponsored Links
  3. Madrab
    Madrab
    4 Oct 2012
    8,210
    Thanks Received:
    2,337
    East Renfrewshire
    Country:
    Yes it will work, but your problem may be what the height of the shower head will be from the cold tank, if you have it on an adjustable rail. if it's too close to the level that the cold tank is at then the head of pressure may not be adequate for a decent flow from the shower.
    • Thanks Thanks x 1
  4. Kaylouise
    Kaylouise
    25 Aug 2013
    2
    Thanks Received:
    Sussex
    Country:
    ok, thank you . In our previous house , the set up was the same and it had a low pressure mixer set on the bath. The water pressure here seems slightly better than there. Hopefully it should work .
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
