- Joined
- 24 Oct 2004
- Messages
- 37
- Reaction score
- 0
- Country
Hi -
We have installed an electric shower (or are about to), a 10K one.. and are due to get an electrician in to sort out our consumer unit so its able to provide a seperate supply (ring?) for the shower from a suitable MCB.
I think we can sort out getting a suitable supply into the loft dirext from the fuse box, to supply the shower, and I have a suitable pull cord isolator switch (like a cooker switch on a cord - with neon light and on/off) So Im ok with wiring all that in ..
however - I also want to add an extractor kit which comprises of a fan, dusking and low voltage light that runs off a transformer...
can I wire this kit onto the same supply the shower uses ? my idea was when I switch the shower on with the pull cord - the light and extractor will also come on - but how does this effect the large load the shower pulls? is this pretty standard a thing to do or should the extractor run off a 'lesser' circuit in the house and obviously be switched using a different switch ?
