Shower hoses - Different size end fittings.
TJL
17 Jul 2012
Essex
Does anyone know where I can get a replacement shower hose that has a standard connical 15mm end and a hand screw round nut on the other end that fits a thread of 15mm so think pipe size would be 10 mm but end has to pass through a hole in the bath of no larger than 19mm.
Cannot look to convert 10mm to standard 15 mm ends on the standard shower hose will not fit through the bath fitting.
Thanks.
Hi TJL, don't know if you are still looking for a replacement shower hose, but I assume you have looked at the large retailers like B&Q?
The other option is online, although with some of the e-tailers you may have to buy more than one as a lot of them are wholesalers. Try http://www.homesupply.co.uk/ they might be able to help. Also you might as well have a quick look on www.ebay.com as it is surprising what you find on there!!!
Who knows - hopefully you have a already solved your shower hose mystery... :mrgreen:
