Hi everyone,
I have a grohe shower and with a dual tap arrangement (one controlling the flow and the other for temperature adjustment). The tap controlling the volume of hot water has a safety button on it which needs to be depressed before it can be turned. The problem is that the tap doesn't turn even with the safety button depressed, so there is no temperature control. It is stuck in a relatively 'hot' position and it's not possible to shower for long before the water turns uncomfortably hot. It looks similar to the one in the pic below.
It's probably a simple job to fix, but I was wondering if anyone had any experience with similar problems on similar taps. Or if anyone could recommend a course of action that I could try before going to the expense of calling someone out.
Thank you in advance for your help!
