    Dismiss Notice
Shower is dragging water out of bathroom sink trap.
Discussion in 'Plumbing and Central Heating' started by RigidRaider, 20 Jun 2019.
  1. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Why has it started doing this in the last few weeks? The trap gurgles as you shower and then the next time you enter the bathroom it stinks of sewers. It never did it before.
    The soil pipe looks to be clear at the top vent, which has a good cover on it. The shower trap is a low profile "waterfall" type. The sink is actually in an adjoining bathroom but must be no more than three feet away from the shower trap, which I think joins the bathroom drain just downstream of the sink waste and the drain runs at a shallowish angle under the length of the bath and out of the wall to join the soil pipe below first floor level.
    Any suggestions?
  2. oldbuffer
    oldbuffer
    6 May 2010
    1,278
    Thanks Received:
    468
    London
    Country:
    If the basin waste has an anti-vacuum valve on it, which would be advised given the configuration you have, it may have become stuck in the closed position. If there is one, try giving it a clean.
    • Like Like x 1
  3. Sponsored Links
  4. Anything slow to drain? You might have something pulling the trap.
  5. Madrab
    Madrab
    4 Oct 2012
    7,723
    Thanks Received:
    2,163
    East Renfrewshire
    Country:
    More likely to be a restriction in the waste somewhere, the pipe will then fill with water causing a vacuum behind it, it will then pull on the nearest trap on the same run.
    • Like Like x 2
  6. Sponsored Links
  7. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Well I cleaned all the hairs out of the shower trap last night - disgusting job - and poured some bleach down the bath and sink wastes and this morning the bathroom smelled okay, so I don't know. It all appears to be flowing ok with no blockages.
    • Like Like x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
