shower not working
13 Apr 2006
can anybody help? iv got a mira sport shower an it just stopped working weeks ago. no water comes out unless you put a tap on for a bit, you get a splurge of water outa the shower when you turn the tap off again. the low pressure lights come on.
Probably blocked. First remove the head and see if water comes out.
Another possibility, especially if you're in a hard water area, is that the heater can is scaled up, but going for the filter first, so this:
1. Isolate from the electricity supply.
2. Remove front casing.
3. Identify water inlet.
4. Isolate from the water supply.
5. Uncouple inlet from shower.
6. Find filter and see if it's blocked.
If you can tell us the age of the shower then we can help you with more precise guidance to the location of the filter.
not sure how old it is, it was already in when we moved in 5 years ago.Its a Mira sport if that helps. it looks pretty old like
Similar problems caused by pilot valve in the shower, it is a common fault on the Miras. But would still go with filter first then the valve.
I'll check the filter in the morning, how do I check the valve?
There is nothing you can do with the pilot valve it is a sealed unit I think. They are not that expensive but being a Mira nothing is cheap. Go onto the Mira web site and they will have information on where to get one.
good news! the filter's ok, iv found out my showers at least 15 years old and its dead! it decided to flood my bathroom on saturday night, we came home to find water pouring through the ceiling so i had to call the emergancy plumber out but he didnt get the message until sunday morning so we spent saturday night with no water or electric. i bought a new shower and iv just been told i need to get a bigger cable and a new fuse board! Aaaaarrrrgghh!!
Thanks for all your help anyway
