Hi guys
I currently have an 8.5 kw shower fitted and the pressure from the shower head is not what I would like it to be. I live in a soft water area and have checked that the head is not blocked. I ran the shower with the head disconnected on the lowest heat setting, turned off and ran the cold water tap on the bath. There seemed to be quite a difference in pressure between the two, would you not expect both to provide a similair pressure?
Would it be of benefit to check the flow rate by measuring the volume of water in a set time period?
Thanks in advance
Thanks in advance
