Hello, had a look through FAQ and other topics but could not find exactly what I wanted to know.
I have two showers running from their own pump which are fitted to the hot water tank and cold water from header tank in the loft. One of the pumps has died and I was going to replace but I am also thinking of replacing the boiler as it is 26 years old and really on last legs. Problem with the shower pumps is they say do not connect to mains pressure, which at the moment is fine.
If I choose to get a combi bolier and remove the loft tank and hot water tank then I can't use these pumps. Is there a pump I can use on both systems? I want to avoid paying over £100 for a pump which I can't use if I change the boiler over.
Sorry if this is a stupid question as new to plumbing but learning fast!!
