Shower Screen Sealant
27 Jan 2013
Hi
Just wondering should a Shower Screen have Sealant on the outside only, or inside too?
The instructions for mine (from Victoria plum), stated seal the outside edge only.
Theoretically, it should allow any water that does get past the seals, to drain back into the bath/shower, rather than rotting the channel from the inside!
I did ensure the wall was waterproofed before attaching the screen and used a blob of silicone in the fixing holes before screwing it in.
I hope that helps :)
I also read that outside only, but when I recently removed our screen to properly clean it and regrout, the scuzzy orangey stuff under it was minging... Maybe the screens need a few mm Packers under them when fixing at the sides. Would allow better external sealant application and better internal drainage too...??
Outside only. The reason is the hollow sections will likely get water in and if they were sealed the water can't quickly drain back in to the tray.
It has always struck me that most shower screens are badly designed. After a few years you start to see limescale on the outer face, particularly where the lowest rails meet the uprights. I have often wondered why they don't drill drainage holes like you find on the underside of uPVC windows.
Depends on the screen, my install instruction said both inside and out, plain glass with no frame.
