Stupid question number eight hundred and sixty-one....
Shower is fitted in a bathroom where the floor level is raised so as to run the waste pipe with the correct fall to the main waste pipe [as it is impractical to run under the floorboards]
Floor is plywood then floor tiles and sealed. Creating an access panel in the floor would not be practical for a number of reasons. Cannot create an access panel on a 'face' below the shower.
PROBLEM - Every shower trap I see has a compression waste outlet. I have never seen one which is solvent-weld.
SO....what happens if the rubber seal in the compression fitting fails over time causing a leak where the trap and waste pipe join.
Any ideas - or am I just being paranoid??
Many Thanks
Many Thanks
