Hi I've got two showers that have both started only getting luke warm. The system is a combi and a hot water tank with header tanks in the loft. All taps seem to run really hot, the flow and return pipes in/out of the tank are both hot when the boiler is on.
The pipe that comes out of the top of the tank gets really hot all the way to the pipes that supply both showers but the showers still only flow Luke warm.
If I've explained things well enough so far.... my thoughts are that it's a blockage of some sort which has affected the flow of hot water? Any help would be great
*the only thing that might have caused this is that the filing loop was found to be left 3/4 open. What might this have done?
