Silicon washer or plumbers mait on basin click-clack waste
DJM
4 Aug 2003
Surrey
I am replacing the downstairs toilet and basin and bought a slotted click-clack waste for the basin as it seemed a good idea at the time. It comes with a silicon washer at top and one at the bottom for sealing when fitting. Are these any good or would I be better ditching them and using plumbers mait instead to ensure no leaks?
My personal preference:
1. Ditch the washer which goes between the flange of the waste and the upper surface of the basin. Replace with a rolled "sausage" of Plumber's Mait.
2. Use a "Basin Mate" on the threads below the basin instead of the supplied washer.
3. Fitting:
3a. Plumber's Mait sausage onto flange.
3b. Tighten waste fitting in as a trial fit, fairly tight but not quite final tightness.
3c. Trim off excess Basin Mait from inside basin. You can wipe any traces off with white spirit.
3d. Mark on thread (or measure from base) where Basin Mate rubber part will go. Remove back nut and Basin Mate
3e. Smear Plumber's Mait on threads where marked (i.e. inside rubber part of Basin Mate).
3f. Reassemble and tighten. Make sure holes / slots line up with overflow channels in basin. Make sure no Plumber's Mait blocking overflow channel.
3g. Bucket under. Fill basin with water, check for leaks. Make good as necessary. Empty bucket elsewhere.
3h. Bucket under. Fill basin with water and continue filling past overflow. Check for leaks, make good as necessary.
Thanks for the reply. Never convinced about the silicone washers.
Not used a basin mate before - will have a look, but it's a small vanity unit and waste thread is limited below basin so not sure it will fit
Fitted three basins in my home with silicon or nylon washers, no problems at all.
To be honest it's the overflow you've got to watch, they seem to leak most easily. Usually the plug hole can clamp down pretty well in my limited experience.
I too am a fan of mait in this instance.
Works first time, every time.
Tried Silicone sealant but cant really test connection until cured, and I ain’t waiting around or coming back to do that 24hrs later! Also a pig to clear when fitting a replacement waste for one that was Siliconed in... mait much easier to remove and prepare surface for new fitting.
