Installation design... no probs
Regs... no probs
Embarrassingly simple practical detail... well, it's got me thinking! So I may as well ask...
Exactly how would you bend heavyish (6mm) T&E 90 degrees where it's clipped flat to a wall? The only position this will happen is where my cooker cable leaves the cooker switch, goes along horizontally, then down to the cable outlet plate (and the hood cable does the same but turns upwards from its FCU to it's outlet, albeit in 1.5mm)?
Will it bend in its 'major' axis flat against the wall within a reasonable radius (so as to stay in the zones) without too much mechanical stress, or would you allow it to twist 90 degrees before the bend, so that it can negotiate the bend in its 'minor' axis, which I think it'd much prefer from a mechanical stress point of view, then twist back 90 degrees after the bend to continue on flat against the wall?
Hope that makes reasonable sense. Cheers,
Liam
Regs... no probs
Liam
