I have to turn an existing cavity wall extension with a low sloping ceiling into an 8foot ceilinged room with a flat roof and the insulation on top of the roof deck. What do I do with the cavity?
Try and connect the cavity insulation with the warm deck. this may mean extending the masonry beyond ceiling level and up to the underside of then deck.
It will then be a case of installing cavity batts as normal.
