single to double
11 Jun 2005
Cambridgeshire
hi all, before ordering a rad i would like to ask if the distance beween wall and valves is the same on single and double im 99.9 % sure but its just my luck !! cheers P M
However you can usually vary the projection from the wall by using the radiator brackets, which have 2 different support points on them. You select the preferred projection and fix the bracket accordingly.
hi helpers .. ive been scupered :( the double rad i was going to fit is 61 mm away from wall as opposed to 40 mm and i cant extend the pipework as its too near the wall is there any fittings i can buy to fit in the valve to extend ? thanks P M
Put sufficient ptfe on the male part toward the back such that when tightened it ios in the correct place and is tight. May take a few attempts, and a lot more ptfe than you expect. Of course hemp and boss white is better but not allowed on potable water.
