Is it acceptable to mount electrical accessories on furniture?On the island unit?
Does that qualify as readily accessible?In a cupboard under the island unit?
Even if that's more than 2m from the hob?I suppose within two metres of the ovens - if one controlling all.
Maybe it's designed to do that but not to have holes cut into the sides for switches?
We've already established this is not a regulation but if so in relation to the oven that would seem acceptable.Even if that's more than 2m from the hob?I suppose within two metres of the ovens - if one controlling all.
Do you think that a surface mounted switch or particularly a DIY'd bracket of some sort, qualifies as good workmanship?
Exactly.Depends on whether either method is carried out by using good workmanship or not.Do you think that a surface mounted switch or particularly a DIY'd bracket of some sort, qualifies as good workmanship?
Quite so. There seems more a little 'arguing for the sake of arguing' going on here. It does seem very odd to see a suggestion that a structure deemed acceptable for mounting a fixed electrical appliance (with fixed wiring) might not be suitable for the mounting of a switch!But just what type of island unit do you have in mind which can hold an electric hob on top but for which some simple method can't be found to mount a switch on the side?
One can go on hypothesising about potential problems for as long as one likes - but that does sound very close to 'arguing for the sake of arguing'. In reality, there are few, if any, problems of the type you are imagining that could not be addressed in one way or another.One with a structure designed to take vertical loads, clad in non-structural acrylic?
Or structural acrylic not designed to cope with the stresses from having a hole cut?
One without a large enough worktop overhang to mean that a surface enclosure wouldn't get knocked into?
One where the cable to the appliance runs where either the switch would have to be on the "wrong" side or where the cable would have to be re-routed out if its void and run back/forth inside the cupboard?
One with no plane surfaces on the sides?
Look at the post after yours to which I'm replying and you might get some insight into thatIndeed - I can't really see where this is heading.....It does seem very odd to see a suggestion that a structure deemed acceptable for mounting a fixed electrical appliance (with fixed wiring) might not be suitable for the mounting of a switch!
