Siting of cooker outlet socket
27 Jan 2006
Essex
I'm having a kitchen refit and a new duel fuel range cooker and electric feed installed. Should the cooker outlet plate be fitted directly behind the cooker? I'm worried it might be affected by the heat generated by the cooker.
I'm only asking because my existing electric cooker (situated in a different location from the new one), has the cable routed from behind an kitchen unit.
Any help appreciated
The cooker control unit should not be sited wher it would be dangerous to access it, such as behind the cooker hob.
The cooker control unit will be sited above the work top near the cooker. My query is with the outlet plate, reading the cooker installation page on this site the cooker control unit should connect to an outlet plate and the cooker connect to that.
behind the cooker seems to be the norm, next to it in a cupboard should also be fine though a little untidy.
it shouldn't generally get hot enough to damage anything behind cookers. usually there will be a gap or a vent or something to let any heat that does exit through the back escape.
Sorry Monki, mis read your post. I agree with Plug. If its dual fuel using gas it will need a stand off bracket as stipulated by the gas regs so should be no problem of heat damage
An incidental point - in my house the outlet plate was behind the space for the cooker, and the switch was above the worksurface to one side, so that you don't have to lean over the burning chip fan to turn the power off (!)
But I was very annoyed to find that the cable was in a conduit under the plaster, running diagonally between the two. Obviously diagonal runs mean I didn't guess its position when I drilled a hole to fix a new cabinet.
In my case I was able to put new cables through the conduit and marked the plaster to show the run, but still, not a good approach.
Is there a good way to run the cable when the switch and outlet are diagonally spaced?
Horizontally and vertically from the accessories. Nothing in the regs to prevent you running diagoneally as long as the cable is adequately protected. Jusy not good working practice as you have demonstrated.
Across and then down, or vice versa, or use earthed metal conduit and then you can put it anywhere
