skimming over rusty screws
24 Apr 2010
Im about to skim a plasterboarded ceiling that had been put up some time ago and exposed to a lot of dampness.Although the building is now dry and the boards seem o.k[a bit dirty though],the p/b screw heads are rusty.Is there something I should treat these with and if so ,what drying/setting time prior to skimming.
16 Jul 2010
Ideally P/boards should be skimmed asap after instalation so a wipe down with a damp brush should remove any dust. However if the boards have had water damage and if the screws are showing rust already I would overboard and skim to solve the problem.
24 Apr 2010
The p/b itself was only exposed to damp not water -they seem pretty sound-just a bit dirty and I was hoping that a coat of p.v.a at time of skimming would deal with that ?
16 Jul 2010
You can give it a go mate but the integrity of the board may have been affected. As for the rusty screws they will rust even more when you start PVA'ing the board and also when you skim. This will lead to rust marks always showing through the decoration and of course they could fail.
19 Dec 2009
Hampshire
if the plasteboard has not been already skimmed and you are worried about the rusty screws, why dont you just replace them with fresh ones?
28 Oct 2005
Clean the heads up if you can't remove them then dab with oil based paint.
24 Apr 2010
Good point Steve-apart from the fact that there is also a rust stain on the p/b[in the countersink]and I was hoping to seal that at the same time.....Would a smear of gripfill do the job?or should I replace screws with new ones,forget about stain on p/b and get on with p.v.a +skim.
19 Dec 2009
Hampshire
i would just replace the screws and skim
