Skirting board help.
19 Nov 2023
As a beginner DIY'er, can anyone please offer advice if MDF plinth blocks can be fitted retrospectively?
I have replaced the skirting board in my living room, but where it meets the stairs, it could have really done with a plinth block as it would look much neater. Anyway, I didn't even know plinth blocks were a thing(!), and now I have already fitted the skirting board.
So, my questions are:
1. Can a plinth block be 'cut in' (like an upside down L shape) so I could slot over the skirting board and hide the joint? (Is this do-able?)
2. Or, do I need to remove the piece of the skirting board, and slot the plinth in.
If anyone has any other ideas, that would be greatly appreciated!
Thank you in advance
You could do either but 1 will be a massive faff without a router and risk looking cark, especially if the skirting has a profile
Better just to buy an oscillating multi tool and cut a plinth block sized section of skirting out , then glue, caulk and paint the plinth block in place. If you're really good with the OMT you won't need caulk. I recommend to run the OMT blade up and down a suitable straight edge rather than freehanding it and cut the entire line in stages rathe than trying to go all the way through (from face to rear) in one point then moving on. This will minimise wandering of the blade
What you're doing is notionally no different to this video:
where they're slotting a skirting board to install a piece of furniture neatly against the wall. Note the use of the multi tool with a straight edge and a gentle gradual cut. Practice on a skirting scrap propped against some vertical surface first or make your practice cut(s) in the area of skirting that will be thrown away when the plinth block is fitted proper
Thank you so much! I appreciate you taking the time to respond
  • It's possible to create a mitered or "L" shape in the plinth blocks to fit over the existing skirting board. This can be done by making precise cuts in the plinth block, allowing it to cover the joint and create a seamless look.
  • Use a miter saw or a coping saw for accurate cuts.
  • Ensure the joint is snug and well-fitted to maintain a neat appearance.
