We have just had a 3mx3.60m conservatory built, which has plastered walls on two sides, with the other 2 sides being uPVC frames with uPVC filled-in panels down to floor level.
The floor is laid to screed and I am going to be laying laminate flooring (can't afford tiles). My plan is to fix the skirting board after the laminate is laid, so that it will mask the gap round the edge between the wall, and ensure a close fit.
My question is: If I am fixing a standard skirting board to the plastered brick walls on two sides, should I glue the same skirting board to the bottom of the uPVC frame, should I simply glue standard laminate beading to the uPVC frame, or should I just leave the uPVC frame bare, with a gap between it and the edge of the laminate
