Sliding Doors.. What do I need?
5 May 2006
Leicester
This might get a little confusing but i'll try and explain..
I have a cupboard that I have made myself with two doors that overlap when they slide. The problem I have is that they do not slide smoothly as they are just wood sliding against the plastic tracking. What would be the best solution to make them slide a little smoother and easier? Many thanks in advance.
We have glass mirrored sliding doors in our bathroom cabinet which slide in the same way inside plastic channels.
They got a little hard to open a while back so I just rubbed wax into the channel and that seems to have helped ;)
Cheers Glassman, thats exactly what the problem is with the doors, its in plastic casing as well. The only problem is that I dont think the waz will have the same effect on MDF... will it?
Cheers Glassman, thats exactly what the problem is with the doors, its in plastic casing as well. The only problem is that I dont think the wax will have the same effect on MDF... will it?
