Sliding Wardrobe Doors - Material Advice Needed
19 May 2006
I've just built a set of sliding wardrobe doors (approx 500mm x 2000mm each) out of 12mm MDF. They were finished with some fancy wallpaper that the wife liked.
The fitted perfectly, but now after a week they have a massive bow in them. I'm assuming that the problem is either the wet wallpaper paste making the MDF go 'soggy' or just the tension created in the panel as the paste dries.
I need to reamke them, and will probably use 18mm something, but would ply be better than MDF?
12mm is a bit on the thin side, I'd have gone with 18mm and made sure that all the faces and edges were well sealed before installation. If you need it Hafele do sell a tensioning rod system for tall doors to prevent/correct this, but it only works with 18 to 22mm doors I believe
Scrit
ok 20% chance of working :D :wink:
take the door off
lay with batton top and bottom leave alone till the bow falls out
paste and paper the other side in the same fashoin and if it dosnt work :cry:
then throw abuse at me for waisting your time :wink:
Maybe glue/screw another sheet on the back for strength? Some 6 or 9mm ply might do it. Flatten it out first though using above suggested techniques.
If it doesn't work throw some abuse at big-all, he loves the abuse :twisted:
Can't I just throw some abouse anyway?!
Thanks people, I'll give it a try.
