Hi, have had trouble with the toilet filling the cistern since I moved in and now really need to sort. It's taking about 20 mins to refill cistern.
The water comes in at the bottom. I disconnected the float completely, but even at max fill, doesn't seem to let much through.
I looked on screw fix and could see a bottom filling option of slightly different design at not much cost, but before I start dismantling or swapping completely, wanted to check if this type is easy to clean/adjust?
It has an isolation valve on the cold water supply which should make things easier.
Advice appreciated, not a plumbing expert!
