On good advice here, I am going to add a Smart socket in an outbuilding being used for external LED light string. (Fused spur)
This is protected from rain etc.
Socket I have purchased (double) is IP66, and expects a round cable and has gland to suit supply cable.
The socket will be fixed, and therefore ‘fixed wiring’
Typically I know flex cables are not used for fixed wiring, but circumstances can allow if no risk of physical damage.
Read that that BS 7671 allows flexible cables, it does stipulate that:
A flexible cable shall be used for fixed wiring only where the relevant provisions of the Regulations are met. Flexible cables used for fixed wiring shall be of the heavy duty type unless the risk of damage during installation and service, due to impact or other mechanical stresses, is low or has been minimized or protection against mechanical damage is provided.
The cable will be clipped direct to rafters, and at least 2m above floor level.
Do I need to use an NYY-J cable to meet ‘heavy duty’ requirement.
Or would I be better to use some heavy duty flexible conduit and run normal 3-core flex inside that)
Total length of run is around 3m
Rest of wiring in building is t&e all direct-clipped and visible.
