Smart TRV that works with Heatmiser neohub
1 Dec 2019
As title says. I am struggling to find a smart TRV unit that can be linked to the neohub.
I want the ability (may never get used) to set individual room temps remotely using smart TRV's. I have UFH downstairs via heatmiser connected to their neohub to give me remote access to the UFH.
Is there any way of linking the 2?
Did you find an answer to this? I'm looking for the same. UFH downstairs and rads upstairs all controlled by Heatmiser but looking for better individual control over the rads in the bedrooms (although not so concerned with it being remote) and don't really want a second hub for a different system.
Have you looked at what the Drayton Wiser system can do. It has smart TRV’s linked to room thermostats and UFH control.
Hi. Hoping to bring this thread back to life. I have this issue as well. Did you ever come up with an answer? Thank you.
I ended up with a nest controlling the upstairs heating and set the manual trv's for each room to how I wanted them heated. Has been ok but the next few months will be the test now the house is finished and winter is here
Having the same problem. UFH in our new extension but radiators in the original house.
Anyone found a solution
Wiser and Honeywell Evo will do both at a significant cost, of course.
Some on here use a variety of alternative, but cheaper, solutions... eg Tado for the smart TRVs and keep the UFH 'as installed' on the neoHub.
I've now worked out the the rads are split into two zones, upstairs and down. The zone valves are controlled by a Heatmiser Wifi neoStats on each floor via the main Heatmister control wiring centre.
Which means I'm stuck with the existing system unless I rewire the zone valves to another smart hub wifi solution which will talk to smart valves on each rad.
There are many smart systems available and most are compatible with Google Home, Alexa etc as is Heatmiser.
Does anyone know if the Google Home App can see both systems at the same time?
