    Dismiss Notice
Smoke cloak wiring to a rio + programming
Discussion in 'Alarms, CCTV & Telephones' started by Thomasthomas23, 8 Oct 2014.
  1. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    I'm having trouble with the programming, the rio won't send a negative signal when the alarm is set (smoke cloak has 2 negative inputs, -smoke & -set these are both programmed on the rio as set and intruder for trigger on the cloak. Any idea's? Thanks
  2. Sponsored Links
  3. secureiam
    secureiam
    20 Jun 2014
    5,284
    Thanks Received:
    652
    Lancashire
    Country:
    What panel, reason I ask is people often cross refer to expanders and rios
  4. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    You can use either set+ or set - on the smoke cloak !.....example set + link the set - to ov ....... Set - link the set + to 12 +
    • Thanks Thanks x 1
  5. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    Thanks, If I full set the alarm, (galaxy G3 48 ) Then I open the door to the garage (this is set as exit/entry) if I don't put the code in and let the alarm go in to alarm, the smoke cloak wont go off straight away there's a bit of a delay. yet if I set the alarm while in the garage (staying still) then move once its set, the cloak goes off straight away, the cloak has a pir which I know is working fine :)
  6. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    That's right :D
  7. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    Can't the smoke work when the system is part set???
  8. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    Don't know what you are getting at ? there will be a delay if you set off in entry.
  9. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    I mean when the intruder alarm is going off (bell box sounding)
    Would of thought the smoke cloak would go off straight away?
    Can the smoke cloak function in part set? Cheers
  10. Sponsored Links
  11. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    Depends on what output / option you have used !
  12. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    I've used output 1021 (SET) & 1022 (INTRUDER)
    They are both set as POS & both latched connections
  13. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    Extra 30 second pre alarm before comms (intruder) ? On entry time out
  14. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    If I do a full set then open the door the countdown starts (15 seconds) then after that the bell box goes off (30 seconds later) with the alarm still going off the smoke cloak then activates (Thr smoke cloak has its own confirmation pir)
    But if I set a zone off which is set as intruder The smoke cloak goes off straight away (with pir activation) also I want the smoke cloak to be active when I part set the system as the garage is part set, then a full set is everywhere. Is there anyway I can enable the outputs to work when the system is part set? Thanks
  15. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    Does it not work in part set ?
  16. Thomasthomas23
    Thomasthomas23
    8 Oct 2014
    20
    Thanks Received:
    Country:
    no doesn't work in part set.
  17. sparkymarka
    sparkymarka
    16 Feb 2011
    8,754
    Thanks Received:
    1,330
    Sheffield
    Country:
    What smoke cloak is it ? 4000/2000 or one of the newer ones ? When you full set it can you hear a bleep from the unit ? If so part set it , can you hear the bleep ? It may be the output you are using from the Galaxy , the ones I've connected where on GARDTEC and premier panels ...
Loading...
Share This Page
