No.Interesting.. I was under the impression (from my builder) that the PB was fixed to the noggings at 2400..
You don't see (plasterboard bonded joint) ceilings criss-crossed with noggs do you? .
Well, technically you're bang on! I'm a software engineer so the number of times I've seen an unfinished ceiling in my life is quite low
So, what centres do you fix your PB at?
And if it's anything less than the joist or stud centres, how do you get that fixing ratio at joins? Couple of YouTube videos I've seen thus far all have noggings and PB fixed to the noggings
Actually, I have another question arising from this for all of you who didn't nog the studs and hence didn't fix to the noggins, but haven't had any problems.. Were your free hanging joints a thick/rough edge or a tapered/smooth?
The other thing I suspect I might not have, is studs that are at 600mm centres. I'll have to get a measure on that and report back, but it may mean that I'm lying plasterboards long edge horizontal if I come across a 2350 wide panel.. Hmm
The other thing it may be prudent to mention.. I was thinking of tape and filling rather than full skim. Perhaps this makes nogging fixing more important, as the surface finish will be thinner at joints and less able to resist cracking
