socket problems
11 Dec 2006
my washing machine runs from a socket which is connected to a fused spur.
when i turn my washing machine on, after a few minutes the washing machine trips out the mains, blowing the fuse in the spur + the plug (both 13amp).
when used on another plug socket the washing machine does not trip out the mains.
also even with the fused spur switch off, just as you put a plug into the socket linked to the spur, you can hear a crackle/sparking noise.
what could be causing this socket to trip the mains?
thats what i thought, going to re-wire it and see what happens
could also be a faulty plug on the washer. Is it new? Its not unknown for sealed plugs to have a bad connection.
but wouldn't this cause the washer to trip the mains on a different socket? as i have been using it on the socket i usually plug the kettle in, and it has not tripped the mains once
Elementary my dear Watson/ Wallsst
machine works in other socket = machine and plug OK
= faulty socket
But there also appears to be a problem with the spur....
Could the w/m socket be bypassing the spur switch? No, because then the spur fuse would not fail.
