Sockets on acoustic wall panel
30 Mar 2015
I’m fitting acoustic wall panels and the wall has a socket and switch. I’d like to mount these on the surface of the panels. This will hide the cut edges of the panels and make the job look neater. They are currently in a metal box sunk in the wall.
Can you please suggest how this can be achieved. Thanks in advance.
The cable terminations behind the socket must be in an enclosure. Obviously you would need to sink a suitable back box into your acoustic panels and mount the socket to the box in the normal way.
I had this issue when correcting snagging, I got PB boxes and measured the required depth, carefully marked and cut the sides to suit. The panels were very white and plates shiny chrome so white worked best in that instance. Extension boxes wouls not have worked as the required depth was very different each side
Make a frame using the same wood as the panels slightly larger than the socket /switch size and fit that flush with the panel?
