I have a problem where my 110mm waste pipe from the upstairs toilet meets the ground. The previous seal leaked so I had to remove it.
I previously used a "multiquick"? type pan connector as a quick fix, but because I cant 'lift the waste pipe up' or 'move the floor down' it doesn't fit flush with the ground, it just points the pipe in the direction of the hole and doesn't provide a sealed fit, leaving a gap of around an inch.
What I need, and what I've been told I can get, is a connector which is thinner at the base, but splits in half so I can fit it into the hole but around the pipe, then clasps together to seal.
Does this make sense ? I imagine a crude example would be a funnel that is cut down the middle, then can clasp together again around the pipe ???
Any other ideas are gratefully received.
