Confusion reigns once again after reading through the BAL adhesive calculator on their website.
(http://www.bal-adhesives.co.uk/bal/pdfs/specifier_literature/BAL_Adhesive_Calculator_path.pdf)
I've looked up the types of adhesive and the coverage figures are quoted for dry and wet areas (wet being the tiling of a shower area)
It goes on to say that for the 'wet' areas a thin bed solid bed trowel is the correct tool.
I've followed the excellent advice of one of the most helpful people on this forum, and I am looking square notch trowels for my walls, but would this only suffice for the 'dry' areas?
Should I consider a solid bed trowel for the tiling of the shower area? if so would "thin bed" be appropriate, in which case would I then need to select a square notch trowel to meet the depth, so that the tiles are all the same level?
Apologies for the number of questions here - the drive I have to get the job done right is immeasurable!
