SOLVED Tool for shutting off water supply at meter
22 Jun 2010
Yorkshire
** Please ignore - have found the correct tool **
I need to turn off the water supply at the meter. I need a tool to do this which is a two-pronged key/wrench with a handle which will reach the shutoff valve. I've googled in vain for such a tool - can anyone point me in the right direction of such a thing (or even supply some dimensions so I can make on out of wood!)
if its out side meter then that wount do it as hex key
if internal then a standard stop tap does the job
