solvent weld waste converted to push fit
4 Nov 2009
Manchester
Morning all,
Could anyone advise on how to convert solvent weld (32mm) to push fit (32mm) pipe??
Is there a straight forward part or do you have to use compression parts?
If you could provide a link to the appropriate part, I would be grateful
Thanks[/i]
the only way to do it is to use a compression fitting, there are many on the market, but without doubt the best by a long way is a McAlpine "MULTIFIT" connector, straight or bend depending on what you need, B&Q etc sells equivelant but they are no where near the quality of McAlpine, worth the extra
http://mcalpineplumbing.com/
