Have installed 2 Zone 1,2,3 mains fed downlighters in bathroom (in zone 2 and 3). I would like to install a third one...however it is zone 1 (above the bath). The units I have bought are suitable, however it does say that a 30mA RCD must be used..... how do I go about wiring this? Can the RCD be located in the attic?
I also have a three pole isolating switch outside the bathroom,which switches the fan (not timer) on and off. Can I wire in the dowlighters so the lights and fan are switched on and off from the switch outside the bathroom (can I also change it to a double pole switch) If it is not possible to wire in the lights to the switch outside the bathroom, can I change the triple pole switch to a double pole switch - and wire the fan into the lights?
Hopeing someone can advise or point me in the right direction. I have checked the reference sticky... but I'm not sure the answers I am after are in there.
Many thanks
Many thanks
