Be careful doing that that you don't exceed the csa of the armour. I won't steal Lectrician's thunder this time...breezer said:To over come voltage drop you use a bigger cable. OR If you have a multi cored cable you use more cores. so if you had a 4 core wire armoured cable you could use 2 cores for live and 2 cores for neutral (earth being the wire armour) which is in effect using a bigger cable.
breezer said:cable is rated by its conductor size (its cross sectional area), not current carrying capacity.
What a tw*t. What did he say when you pointed out the range of sizes available - did he have any theory as to why T&E was available in these sizes, and why it should all be called 13A cable, and not, for example, 6A cable, or 27A cable, or 50A cable?AdamW said:I had an idiot at work who kept on "correcting me" every time I said "twin and earth" by calling it "13 amp cable". He insisted he was right and I was wrong. And he is a professor![]()
