sorry part p.question.
12 Nov 2005
i am a heating engineer of many years,i fully understand that electric has to be used safley.
1.can a minor electrical installation works certificate be issued by me for work ie new gas central heating installation,when electrical work done by others.all run from existing fused spur.
2.can a part p qualfied person [b&c] install a spur from a ring main to provide power for a gas central heating system.
thanks in advance and i promise i will never post any more part p questions.
The person doing the work should have issued the Minor Works Certificate, it should not be issued by someone who is not responsible for that work.
You can issue a PIR if you have tested it and are qualified to do so, but you should ensure that you test it properly if this is the case.
Yes. A part P regsitered installer can install a afused spur for a central heating system, that is the whole point of making Plumbers comply with Part P and becoming registered.
thanks big spark,by the way how did you get that name sounds dangerous,just like heating fitters wiring we have a love of non heat resistant flex.subject closed.
It's because I'm 1.94m (6ft 4") tall, weigh almost 127kg (20 stone)..and am only about 5kg overweight..(about a stone)
that makes me a big_gas,smell usually after 11 pints of guinness and a hot indian curry,yes.
