Soundproofing terraced house
Status
Not open for further replies.
29 Mar 2021
Hello
Please could anyone help with some soundproofing advice?
Because of loud traffic noise and living a pavement's width from a busy road, I would like to add some soundproofing to inside of this wall.
Could someone help with the following please?
1) What is the best soundproofing and method for this wall with a lot of external noise - approx 12 foot wall
2 What is the best soundproofing and method for an internal wall between a neighbouring house
Any help would be very much appreciated. If anyone knows a rough cost per foot/metre as well that would be great.
Thank you
Morning,
1) Unless you have holes in the masonry, the walls are not going to be the problem. The windows will. Good fitting double glazing is pretty good at general traffic noise but at the distances you have stated, you might need something a bit more robust. There are a raft of double glazing options which offer more protection from noise ingress. Pilkington's Optiphon range are pretty good but it will probably be quite an investment of ££££. It would probably be worth paying someone to do some proper noise measurements at your external façade and some noise ingress calcs to advise on the most appropriate means of uprating the glazing. Alternatively you could look at retro fitting internal secondary glazing. This can be really effective but intrusive and ugly.
If you do have holes in your walls, plug them up. Be careful though as you might end up with a mould problem if you don't have enough ventilation. If possible, move any external wall vents to a less noisy façade.
2) Sound insulation between properties can be more complex. If it is just noise through the fabric of the wall then you want to look at de-coupling the internal lining from the party wall. Gosforth Handy man (see his excellent Youtube channel) recently included some of his work in adding sound insulation to internal walls. Basically, you will need to look at resiliently mounting an internal lining of plasterboard (ideally two layers) to the wall and fill the cavity with a suitably dense mineral wool / rock wool. Again, check there are no holes in the wall first.
If you have a problem with flanking sound i.e. the properties share joists or have a solid party wall, then you will have more of a job. Again you need to de-couple your property from the neighbours.
Sorry I can't offer any costs. The scope and scale of the work depends on a lot of factors and I wouldn't know where to begin with that.
Cheers,
BBM
If you can afford to loose 100mm then a stud wall 50mm off the house wall packed with Rockwool Soundslab would be decent. It would cost about £150/£160 in materials then need a plasterer to skim it.
Hello, thank you both for the advice.
I do have air vents on this wall that lead into the cellar and I think a lot of the noise is coming up through the cellar roof so that is going to have to be insulated to try and help the noise as well. I will have a look at the video, thanks for that.
I could afford to loose 100 mm for a stud wall.... anything to get rid of the noise!!!
Thank you both so much ;);)
Before giving up 100 mm, I’d separate the two problems.
For the road-facing wall, the windows, cellar vents and route through the cellar ceiling are likely to be the weak points. A new lining on solid masonry may achieve little if those paths remain open. Secondary glazing with a generous air gap can help, but required ventilation needs a properly silenced alternative rather than simply being blocked.
For the party wall, an independent or resiliently mounted lining with mineral wool, two plasterboard layers and a fully sealed perimeter is sensible. Sockets, joist ends and rigid fixings can otherwise bypass the lining.
If space is limited, XXXXXXXXXXXXXXXXXXXXXXX are one option worth comparing with a full independent stud wall. Check tested improvements on a wall similar to yours rather than relying on a headline dB figure. No wall system will correct noise still arriving through the windows, vents or cellar.
You're wasting your time. Keep your money in the bank, save like mad and move to a house you enjoy living in.
I'm speaking as a former terraced house dweller who now lives in a detached house in the countryside. I'm glad I didn't waste money trying to turn it into something it could never be. Treat it as a stepping stone.
If you start soundproofing you'll just spend a load of money making your rooms smaller and actually reduce its resale value. If you don't tell buyers you've done it they'll just think it's tiny. If you do tell them it has amazing soundproofing then they'll assume there's a screaming maniac next door and go elsewhere.
Some people are genuinely unbothered by noise and could live next to a motorway and be happy. You're obviously not one of them, and neither am I.
Look at all the previous threads in the forum on soundproofing - there are quite a few!
Secondary glazing can help with soundproofing - worth being aware than the optimal distance between panes for soundproofing are different than for heatproofing.
Oops ancient thread - thanks for the heads up!
I really want to know if these bots are created by the site owners themselves or if they just turn up and start botting.
It's spam, plugging a brand name of stuff you can buy. No website link and quite a well written post, presumably by AI. They're getting craftier and more difficult to spot.
Reported.
I'm not bothered. I find it interesting how clever spam is becoming.
But I doubt that any AI software is bitter and negative enough to completely blend in here.
Status
