Spaced out "up top"
  • Thread starter cantaloup63
  • Start date
C
cantaloup63
Nice simple one for you. I intend to board out the loft for storage (using 8 by 2 moisture resistant flooring chipboard), so to strengthen the joists and avoid having to faff around re-routing wiring I intend to screw some 63 by 36 CLS studwork timbers to them (at 90 degrees). So, what is a good spacing to use between them?
Cheers
15 Nov 2005
Gloucester
Cook Islands
space them to fit the loft insulation rolls that you are going to put down. This might be about 600mm
