Splitting cat6 poe
31 Aug 2005
OK my brain hurts. I have a CCTV cam and wish to extend Wifi so i want to add a Ubiquiti Mesh AP to the same area. At there is only one Cat6 i was intending to split this to Cat568b at the CCTV end to supply Wifi AP also. Will poe work let alone supply current?
Something like this
Thanks.
Not usually like that.
There are several variants of Power Over Ethernet.
Alternative A transports power on the same wires as data for 10 and 100 Mbit/s Ethernet variants, so you could use the cable splitting technique to make two 2-pair cables from one 4-pair cable.
Alternative B separates the data and the power conductors, and uses all four twisted pairs in a typical Cat 5 cable. The positive voltage runs along pins 4 and 5, and the negative along pins 7 and 8, so you couldn't split the cable.
For Gigabit Ethernet and faster, all four pairs are used for data transmission, and for 4PPoE all four pairs are used for power transmission, so you couldn't split the cable here either. This enables higher power for applications like PTZ cameras, high-performance wireless access points, or even charging laptop batteries.
Also, PoE devices have resistors in to signal to the power supply what type of power they need. This probably rules out splitting the power to multiple devices without using a POE-powered PoE-supplying network switch/hub. I don't know if such a thing exists or how much it costs.
(from https://en.wikipedia.org/wiki/Power_over_Ethernet )
