Spot Lights
Lets forget about the light fittings for now...
and say that you have a supply L & N and a switch
now if you take a L from the supply to the switch, the switch will switch that,,, so you connect your blue (sleeved brown) to it.
At the other end you will now have a L, N & switched live (blue, sleeved brown)
Now if you think about it you should be able to figure which to connect you light fittings to..
AND BTW do not cut the earths short... sleeve them green/yellow and terminate them in some terminal strip..... yes even at the fittings!!!
I fear he may have wired in 2 core.
Electrician1, can you confirm the type of cable you have used?
Im not 100%, but I have also had a long day, I will look at it again tomorrow with a clear head, and if needs be get back to you, thank you for your time.
It only has 2 Brown and Blue. as the spots are not earthed . When the switch is "off" the breaker goes. The lights come on when the switch is on "on"
Has he put the earth wire into l2
So you are saying that it only needs one feed (Live to L1!) what about from the celling rose,. Do I only connect the Live there as well, ?
Are you sure (steve et al) it is so Banesk to question this person competence and check he is not doing this work for a third party (unknown). Surly it is correct to ask some questions. I stand by my question that we need to know if he has a multimeter/tester or not. Some simple tests will resolve this a great deal easier than drawing diagrams that he clearly does not comprehend.
How can he not comprehend them - he's an electrician.
Maybe he can't comprehend them any more than nobody seems able to comprehend that he's actually another one of the pathetic and inadequate little trolls that pop up now and then.
Its peoplelike you who give others a bad name, just because someone cant do one thing does not make them inadequate, people like you should shut up if they have not got anything good to say.
You call yourself "Electrician1".
Either you are not, which makes you a liar, or you are but you are pretending to be incompetent for your own amusement, which makes you a liar.
No. If he had, the light would never work in either position.
I made that diagram as easy as possible to understand. That, however, was my last attempt at helping him. If he cannot comprehend simple GCSE physics, he has no chance at wiring these lights, and needs a real electrician. I would sincerely hope that he is not doing this in somebody elses home, given his level of incompetence. I am all for helping DIYers, that is what this site is about, but you have to draw the line when even simple GCSE wiring, which is taught to everyone, is not understood.
