Sprinker systems are mandatory in all new houses in Wales. As the Grenfell Tower disaster will almost certainly require sprinklers in all high-rises (a high rise is between 7 and 10 floors). Installation in all new homes all over the UK will follow for sure. Probably mandatory in all high rises with instant retrofitting.
If you have an excellent mains water flow and pressure, these can be off the water mains.
https://www.deevalleywater.co.uk/wp-content/uploads/2016/03/rev-c.pdf
They are very simple when off the water mains needing some calcs on water flow and pressure. I know in the likes of high rises they need a yearly inspection and approved on installation.
DIY fitting one in a building that the regs do not require is worth it. It does not need the annual inspection then - a nice extra personal safety measure.
Does anyone know where to buy the sprinkler heads?
Some are quite neat being just a round white circle on the ceiling.
