If it were tested as a radial, then it presumably would 'pass' the continuity tests. However, that would leave the possibilty that a broken 'ring' or bridged 'ring' may have gone undetected.Indeed. The house currently has an ECIR, but the 6mm spur had been taken out of the CU and connected behind the board with choco block into two short lenghts of 2.5mm and thus disgused, and oddly, passed the continunity tests with ease...This, of course, is where one of the potential problems arises. Since it's not conventional and hence probably 'not in their I&T book'....
Indeed. As I said, I think the more labelling and documentation the better!If its labled as 'Conservatory Ring, inc boiler and light' and is then a single peice of 6mm I would have thought that would have given at least some of the idea as to what they might be looking at? I am also going to lable all the wires coming in/out of the junction box as to what they are. I might write 'lollipop' on the 6mm as it goes into the breaker!
Kind Regards, John
