Funny isn't it that we can't make 'flammatory' remarks, or get an ointment for 'flammation'.To inflame tensions?
Perhaps he finds that making inflammatory remarks creates a sense of urgency?
The IEC (like CENELEC, BSI, etc) has preferred terms to facilitate illiteracy. "Flammable" is their preferred term for things that can be ignited because their preference is to pander to the hard-of-thinking.
Blame the Germans.Perhaps it is your - IEC and others' - use of flammable which has caused people to believe inflammable means does not burn.
That is all true. However, as I have said, the situation is confusing (in a potentially misleading/dangerous), since most 'ordinary people' will not be aware of the etymology, but are aware of the way in which, when there are a 'pair' of words (one with the "in" prefix), the "in" prefix often signifies negation. As you go on to say ....One does not mean the opposite. That some people do think that does not alter the meaning. The correct usage cannot be deemed wrong.
I wouldn't single out any particular organisation, but the problem I mention above (leading to potential ambiguity) only really exists when both an "XYZ" and "inXYZ" are both being used to a significant extent at the same time....Perhaps it is your - IEC and others' - use of flammable which has caused people to believe inflammable means does not burn.
They may (to some extent) be the first, in English.Do you not find that the word "inflammable" is sometimes misunderstood BAS? Especially by people whose first language is not English? Are they all illiterate, or hard-of-thinking?
They are, if I understand you correctly; e.g., translation into German is done by the Germans, French by the French, etc. That process often reveals ambiguities in the English, which we then try to remove. There are many translations that are not performed with the knowledge of, or contribution from, the Working Group, so if there are remaining ambiguities it is possible that those translations could be technically incorrect.surely that each standard, once developed, should be translated into {whatever} by or with the assistance of those involved who speak {whatever}?
"Inflammable" is not an ambiguity.That process often reveals ambiguities in the English, which we then try to remove.
Which means they are done by professional translators. No such person worthy of the name would not know what words mean or not know how to find out.There are many translations that are not performed with the knowledge of, or contribution from, the Working Group
It is for some countries."Inflammable" is not an ambiguity.
No it doesn't. It's usually done by someone who knows something about the subject, and nearly always by volunteers.Which means they are done by professional translators.
That's all very well but, as I'm sure you understand, anyone who says that clearly has no understanding of the derivation, hence meaning, of that word. As I said before ("insulator", "inferior" or "interesting", etc.), not all "in-words" are derived in a manner which makes the "in" a negation of what comes after those first two letters.Involved in a car accident, I was lucky to be injured but all the other occupants sustained multiple juries.![]()
Clearly - like those who think inflammable means 'does not burn'.That's all very well but, as I'm sure you understand, anyone who says that clearly has no understanding of the derivation, hence meaning, of that word.
Like 'inflammable'.As I said before ("insulator", "inferior" or "interesting", etc.), not all "in-words" are derived in a manner which makes the "in" a negation of what comes after those first two letters.
Lucky you weren't volved!Involved in a car accident, I was lucky to be injured but all the other occupants sustained multiple juries.![]()
