So why are you bothering to continue reading pages of post-original-question discussion that apparently doesn't interest you?Exactly![]()
Kind Regards, John
Why have you never heard the term Subject Matter Expert?Why do we need people who are bi-lingual and small-or-medium enterprises?
Ah. Yes, I've heard of it, but (probably because of the obvious potential ambiguity), I don't think I've ever seen it abbreviated to 'SME'.Why have you never heard the term Subject Matter Expert?
Ah.Ah. Yes, I've heard of it, but (probably because of the obvious potential ambiguity), I don't think I've ever seen it abbreviated to 'SME'.
Nor me. What activity(ies) is that abbreviation used in?Yes, I've heard of it, but (probably because of the obvious potential ambiguity), I don't think I've ever seen it abbreviated to 'SME'.
As I said before, same here.Well, it's a new one on me. I've heard the expression Subject Matter Expert, but never to my knowledge has it been abbreviated.
In a document, if it were defined in a list of abbreviations, or even just defined at first usage, that would be fair enough.Why would it NOT be abbreviated if appearing several times in a written piece?
Well, it clearly depends on what circles one moves in, what one reads and what TV etc. one watches. Maybe you don't watch Newsnight or business-related programmes!I wouldn't have known. .... I suppose it depends on one's line of business:
To avoid confusion with the common abbreviation for Small to Medium Enterprises.Why would it NOT be abbreviated if appearing several times in a written piece?
No-one has suggested that anything "stops it being an abbreviation for something with the same initials" (which it clearly is). However, what is being said is that (from the point-of-view of common sense) if there is a common meaning for the abbreviation, then it is foolish to use it for something else (which has the same initials) unless one knows that one is talking to someone to whom it will have that different meaning.I don't see that as being a good reason. ... Just because one is more common (if, indeed, it is) does not stop it being an abbreviation for something with the same initials.
I try never to use that abbreviation, for that very reason. Fortunately, people rarely talk/think of a "Radial Final Circuit" (rather, just "Radial Circuit") - otherwise the potential ambiguity would be much greater.Is that why RFC stands for Ring Final Circuit and not Radial Final Circuit? Except, of course, it does.
