Spurs from breaking into ring main
Maybe because they fester away under floorboards and, when they fail, it's the fire brigade that gets called out?
Yes, that's obviously a factor.
Unfortunately, it would be impossible to get any even half-reliable statistics about that. Apart from anything else, the fire brigade seem to have a habit of describing any fire of otherwise unknown cause as "electrical", and there is probably rarely enough evidence to prove them right or wrong.
However, even without problems (fires or whatever) arising, electricians must have a lot of experience of ripping out old installations during the course of a re-wire, and I wonder how often they see any evidence of loose connections (or other problems) in JBs?
Although I may well be wrong, I must say that I find it quite hard to see how loose connections in a JB could, under normal load conditions (i.e. limited by an OPD), start a fire - unless, I suppose, the JB were buried in highly inflammable material. It is, after all, very hard to set fire to wood even if it is in direct contact with red-hot metal - and that shouldn't happen with a JB, anyway.
Kind Regards, John
Edit: crucial typo corrected
The odd thing is that one does quite often hear about problems having arisen because of 'loose connections' at sockets and switches (particularly shower isolators) etc., but not that I can recall in relation to JBs.
Shower isolators have a powerful spring loaded action - I can see how the vibrations from that might work a screw loose over time, if it wasn't tight enough at the start.
Inflammable is actually correct - although going out of fashion because of the confusion.
The OED states: "The words inflammable and flammable both mean 'easily set on fire'. Inflammable is formed using the Latin prefix in- which has the meaning 'into' (rather than the more common use of in- to indicate negation), and here has the effect of intensifying the meaning of the word in English." However in technical writing, the word used is "flammable", to reduce translation errors that might otherwise result from the more common usage of the in- prefix.
I'm not American
AFAIK the term "inflammable" is more common in the USA.
This from Merriam Webster (American):
The OED states: "The words inflammable and flammable both mean 'easily set on fire'. .... However in technical writing, the word used is "flammable", to reduce translation errors that might otherwise result from the more common usage of the in- prefix.
It's certainly potentially confusing/misleading. However, I am all but certain that, at least in terms of 'everyday English', "inflammable" was the word almost invariably used for at least the first 2 or 3 decades of my life (and "flammable" sounded 'wrong', and was generally thought to be 'American').
EFLI's (American) dictionary seems to think otherwise.
Kind Regards, John
Well, you cannot "correct" them, as such.
You may say, to avoid confusion in Britain (where they don't know the meaning of words) we use 'flammable'.
You may correct them when they use 'inflammableness',
