Standard steel bath recommendations
JP_
17 May 2012
Can anybody recommend a standard steel bath 1700x700 you've recently purchased and fitted.
Too many options online.
Is there a guide to min weight? Saw one in B&Q that looked alright, but one reviewer suggested 20kg was too light.
Most sites don't seem to share steel thickness or bath weight. I guess heavier the better in general.
There are plenty of Kaldewei steel baths on eBay but you do have to check the specs very carefully e.g. tap holes, legs
I was recently planning to change the bath but decided to make do in the end.
I have a Kaldewei, I think they do 2 thicknesses - mine is the thicker and very solid.
I’m not sure what weight has on the choice of bath? The other thing is, they damage easily if something like a tile is dropped on them, but suppose that can be said for any enamelled steel bath.
I just read one poor review of a B&Q steel bath being a bit flimsy at 20kg, and see that the premium models are around 40kg. But, maybe they are all ok and some people are just fussy!
Yeah, need a good tiler with lots of blankets...
What sort of waste? Does it matter?
eg.
Kaldewei Comfort Level Pop Up Waste £181.00
https://www.sanctuary-bathrooms.co.uk/kaldewei-comfort-level-pop-up-waste/
Bristan Economy Bath Waste with Brass Plug Chrome - Slotted £24.95
https://www.heatandplumb.com/acatal...ste-with-brass-plug-slotted-Chrome-w-bath10-c
I'm not actually a fan of pop up wastes after one got stuck in a basin and I had to drill a hole into it to dislodge it.
Is there any point in paying 7 times more for a special waste?
I am veering towards this bath anyway
Twyford Neptune Single Ended Rectangular Antislip Bath with Grips 1700mm x 700mm 2 Tap Hole
https://www.heatandplumb.com/acatalog/twyford-neptune-single-ended-rectangular-bath-ne9572wh
Probably recommend the cheaper one, I’m not a fan of pop up’s either.
