Stanley Cooker
sws
11 Jan 2004
I have a 10-year-old Stanley single burner range (old type - with baffers). I am curious as to something, which has started happening lately. Perhaps someone can help.
This is what normally (should) happens: The range is switched on, either by switch or thermostat; you hear a noise (noise X) and in about 5-10 seconds the burner fires.
However lately, Noise X is significantly quieter on occasion(you would have to be right up beside it to hear it), (maybe 1 in 30 times the cooker is switched on.) It sounds like the sound you would hear if you were to hold a small bench grinder and switch is on. A kind of a faint whine. After a while you will hear a click from the bottom left of the range and the burner fires up violently. Any idea what this might be? Is it doing damage?
Thanks.
Could be one of several things.
When did you last have it serviced?
How long did it take?
Has been serviced every year since we got it is due a service in about 4mts time. The service man takes about 4 hours. Any info would be much appreciated.
Sounds like he does a good job, best to give him a call. I'd be intrested to know what the cause.
Had the service man out today, pump and motor capacitor replaced.
