Static home supply
4 Feb 2007
Surrey
I went to look at potential job in a static home the other day and was amazed to see the incoming supply to CU was wired in 2.5 T&E, I checked outside and it looks like Pyro is the supply to the static it then joins the T&E
in an external joint box
Is this right?
Is it wrong?
What is the overcurrent protective device at the origin?
What is the size of the Pyro?
What loading is expected?
Where is the T+E run?
What is the earthing arrangement?
Did'nt get to see OPD
Pyro looked small i'm guessing 2.5
1 Lighting circuit,1 Radial, Heating and cooker
T&E runs under the home then comes up through floor
