STATIC PROBLEMS
8 Feb 2004
Wolverhampton
Why is it that after being at my computer, if I get up and touch my Hi fi ( metal case ) I get a small shock :?: :(
My electrics seem to be fine and I have an up to date consumer unit. :?
If it is static then it is down to the flooring type and/or what you wear or even the type of material the seat is made from.
PVC seat and a nylon shell suit are a good mix for static..
if you add cheap laminate flooring to that with that foam type underlay to it then it's even better..
pluss lots of moving of the arms :shock: helping to stip the electrons off the chair and onto you...
if it's that much of a concern to you i'd suggest investing in an anti-static wrist strap or ankle strap connected to a decent earth..
Been working in a block of retirement flats for a few weeks and its really getting to me, nylon carpets, every time I touch the earthed metal button on the lift I get shocks, had one today where I actually saw the spark!
Any ways to slowly discharge the static?
Just using an insulated screwdriver to press the button now :roll:
Thanks for replies.
I get static when I get out of the car too. :(
Any links to anti static products pls :?:
Try this little lot http://uk.rs-online.com/web/search/...earchProducts&searchTerm=anti+static&x=24&y=8
Did you know that most static discharge shocks are anything upto 20kv, something like a discharge from a gap of say 0.5 mm can be in the region of 2kv - 4kv.
I personally had a nerve fried in my back from static discharge, it was somewhere in the region of 200kv, so if you think that a wee zap from a car hurts then think of me, knocked me out cold, nice bit of compo though :)
When you get out of the car dont close the door by touching the bodywork, close it by putting your hand on the glass instead ! alternatively get one of the grounding strips from a motorists shop, the rubber strip has a wire inside it that touches the road thus dissipating ( big word for a sunday ) any static build up.
