stick welder
4 Nov 2007
Stirlingshire
hi,
can anyone help with a question,
low amp welder, what size of stick should i use and what sizes can you get.
thanks
donny mac
It depends what you are going to weld. Sticks are usually 2.0mm, 2.5mm, 3.2mm or 4mm for light work.
is there a general rule of power to stick size or can i use anysize of sick with
low amps, would be welding mild steel, car wings etc.
Youll be struggling to put on car wings nicely with a stick welder.
If you must though, 2mm rods.
For more info on welding , have a look here- primairly for MIG welding, but has MMA section aswell.
Forum should be back up and running very soon.
http://www.mig-welding.co.uk/
Throw the stick welder in the shed and get a Mig or you'll make a right balls up of it !
thanks guys for the info...
im only doing minor repaires so will stay with the stick for now..
cannot use the mig because it needs to be portable and i dont have a power supply in the garage..
thanks again
donny mac
You`re a fine man--to be able to work one of them :eek: I tried a low amp mains one , and wasted £60.00 about 15 years ago :evil: binned it . and Borrow mate`s MIGs. now :LOL:
